show radius dynamic-authorization
show radius dynamic-authorization index
Description
Displays the current RADIUS client dynamic-authorization status.
Syntax Description
index RADIUS server index.
Default
N/A.
The following sample output displays the current RADIUS dynamic-authorization status:
# show radius dynamic-authorization
RADIUS dynamic-authorization: disabled
The following sample output displays the NAS-IP Address requirement set to require (default).
RADIUS dynamic-authorization: enabled
RADIUS DynAuth server:  1 Status is Active
    host name     :
    IP address    :  10.51.1.181
    Server IP Port:  3799
    Protocol      :  UDP
    Client address:  10.50.97.80 (VR-Mgmt)
    shared secret :  #$LG11P/fwCjVyH1LlEqSeBrbGr/EXKQ==
    NAS-IP        :  Require
This command was first available in ExtremeXOS 22.1.
Platform Availability
